white500xl
- Joined
- Jan 16, 2009
- Messages
- 32
What parts cleanibg fluid is the best, mineral spirits or soap based?
PSC1000 from Tractor Supply works great! I've also successfully used Mineral Spirits from the paint department at the big box stores in my old 5 gallon washer before they outlawed it in CA.Solvent-based. I like Crown PSC 1000.
Here on garage journal I learned that Simple Green destroys aluminum. Be careful with those expensive aluminum parts.I use Simple Green in my BikeMaster parts cleaner. It works well for me. I always wear gloves with any parts cleaner.
This is addressed directly on their website.Here on garage journal I learned that Simple Green destroys aluminum. Be careful with those expensive aluminum parts.
Varsol is still available.I use Crown PSC 1000 as mentioned above.
I regard it a barely adequate. It doesn't work nearly as well a Varsol from days gone by, but as far as I know "Varsol" is either no longer made or at least no longer available to non-industrial customers. I think there were health issues with Varsol so hopefully the PSC is safer at least.
What are the thoughts of Kerosene ?
In CA you are supposed to use locally sourced granola in a solar powered ultrasonic cleaner.I’m in the ‘spirts camp.
It’s the EPA and tree huggers that have pushed for the “water-based” alternatives. Probably won’t be much longer and that will be out also. We’ll be using some kind of “dry” cleaner- like dry shampoo!
