Parts Washer Solvent
D45
NW INDIANA
I acquired a free BNIB part washer solvent tank
I have a NG garage heater somewhat close to where I want to place it, so I am concerned about the type of solvent I will be using
What's a good type that isn't really flammable?
The degreaser they sell at Harbor Freight works well degreasing. You need to use it at about 50/50 and I don't know how well it would last for a long time in a parts washer tank.
D
D45
NW INDIANA
I also don't want it to freeze in the tank over the winter, even though my garage is heated when I'm out there working
Pinemarten
Washington
Non-flammable and non-freezing is a tough requirement. Old school parts washers used Stoddard solvent which is flammable, close the lid when you aren't washing parts. It was like having a running faucet rinsing the parts. The solvent drains into the tank to improve safety.
Here is the MSDS:
Maybe some water-based solvent could be mixed with a anti-freeze agent that wouldn't compromise the cleaning action.
D
D45
NW INDIANA
If the lid on the parts tank is closed when not in use, the parts tank is about 10 feet from the NG ceiling heater, and there parts tank is in a separate room of the garage (door can be closed when in use).......think I would be ok with a solvent?
D
D45
NW INDIANA
PSC-1000 from Tractor Supply is like $48 for 5 gallons
My tank holds 12 gallons so hopefully two containers fill it up enough
Schurkey
Why do you need a "full" tank?
My "tank" is a 30-gallon drum. I typically run four gallons of low-odor mineral spirits in it. I rinse parts using clean mineral spirits from a "garden sprayer", and the runoff rinse solvent kinda replaces what evaporates out of the tank.
ctandc72
VA
The Tractor Supply works well but after trying OilEater - I'm sold.
Bryanbdp
Avon CT
I've used kerosene in the past. Much less flammable but not as aggressive cleaning. I floated it on water so the crud would drop down into the water layer. Pump has to be suspended in kerosene layer.
Sumboodie
AK
As I understand it, stoddard solvent is the same thing as paint thinner...
No, paint thinner is less refined. It's more oily, smells more and lower flash point.
You're thinking of mineral spirits.
4x4Pete
Stroud
Any flammable or caustic vapors can cause damage to your heating equipment. If it was a direct vent type (sealed, ducted combustion air supply rather than room air for combustion) furnace you would have no issue with any of the solvents. If it isn't, can it be set up as a direct vent?
Jagmandave
Overland Park, Ks.
I use Crystal Clean, it's similar to Safety Kleen, they come and haul off my old one and drop a new one for me, cost is $167 delivered for a 25 gallon barrel (less than $7/gal, delivered to my shop), and I set my HF parts washer right on top.
D
D45
NW INDIANA
Valid point. I just read the manual and it said to use 12 gallons
I will try a single 5 gallon container and see how well it full the wash tank, to hopefully cover the pump inlet
MacMcMacmac
canada
Stoddart solvent, mineral spirits, Varsol, whatever you call it, is not very flammable.
My co-worker was leaning on a cut off disc one day and it was dumping a solid blast of sparks directly into the parts washer and nothing happened. My father actually had to tell my brother in law's father that he had to shut off his kerosene heater after he filled it with Varsol given to him by a co-worker, after my dad noticed by the sight and smell that it was not burning properly.
It can be rough on your hands, but it is not a fire hazard. It cleans well, and can be had in a low odour format. Once it has a bit of oil mixed into it, it's a bit easier on the skin.
BillK
Beautiful Southern Maryland
Safety Kleen will sell you what you need and will also come and dispose of it when needed. I have one Safety Kleen solvent type washer at my shop and it is about 10 feet away from the ceiling hung gas heater. Its not an issue.
D
D45
NW INDIANA
I picked up one 5 gallon container of the PSC-1000 from Tractor Supply
They had 3 containers in stock, from 25 early last week
