Pass through adapter
wolf_from_wv
WV
Is there an adapter for using the larger 3/8 drive sized sockets with the Craftsman 1/4" drive sized handle?
I was trying to tighten a switch, and the 10mm smaller socket didn't fit over the end of it, but the larger 10mm socket did fit.
signcrafter
They do make adapters for that. They also make a stubby 3/8" drive ratchet in a 1/4" ratchet.
kc-steve
Kansas City
I'm a little confused. There are "pass through" tools of many types, but then you describe tightening a switch with a larger socket. Sounds like the problem was solved, but I probably would have used an open-end wrench if I understand you correctly.
Steve
