Patching Concrete Block?
CHuDWah
Kritter Krick, Flaw-duh
The inside walls of my concrete block garage have some holes from toggle bolts the previous owner used to hang stuff - they're 2" or so in diameter. Never having patched masonry, I have some questions:
1. What's the best filler to use, preferably premixed?
2. How do I keep the filler from just pushing through the hole into the hollow block? A backer of some sort?
3. Should I build up the patch with thin layers, or just one thick layer (I'm guessing the latter)?
4. Any other advice?
NYBODYMAN
NY
What about mortar caulk? Squeezes out in a caulk tube. I used that on my block basement for the same thing and it worked fine.
Leaflessshadetree
Don't ask.
1. Chisel all of the holes so the patches will lock in.
2. Pack the voids with crumpled news paper.
3. Wipe one hole with a wet rag to remove any dust or loose chips.
4. While that hole is still damp Mix up enough hydraulic cement to patch 1 hole.
5. Trowel it in smooth with the wall (it sets up quickly).
Repeat steps 3-5 for each hole.
mm08822
Hydraulic cement is best - it expands slightly vs. shrinking as mortar does. It sets up quickly so you can progressively patch a hole by building it up in a short time.
Finishes off nicely too.
Bighead38
Rockland County NY
If you don’t want to mess with cement just use some spray foam. Cut it even with the wall when it drys.
Personally I would just mix a small amount of something quick setting and patch it.
DTE
North Carolina
I use Alex painters caulk, they make a Slate grey that matches unpainted block fairly well. It takes 2 to 3 applications to do a nice job.
C
CHuDWah
I neglected to mention we're going to paint (actually repaint) the wall after it's patched, so color match isn't a concern.
juddspaintballs
Hedgesville, WV
I've patched concrete block in my basement with hydraulic cement. It was easy to shove into the hole by hand and it set up very quickly. I'd use that.
C
CHuDWah
When I ask for and get advice, I think I should report the results, so...
I used hydraulic cement. The directions said to chisel the back side in a "V" shape to hold the patch but the holes really weren't big enough to do that - they were broken through in pretty much that shape anyway. I wiped out the dust with a damp rag and wet the holes with a spray bottle. I mixed the cement as directed (3:1), packed as much as I could in the hole, and leveled it off with a putty knife. It hardened quickly and hasn't fallen out so I guess I'm good. :thumbup:
Still have some small masonry screw holes to fill - I'll probably use concrete caulk for those. Then ready to paint...
<!--[if !mso]> <style> v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} </style> <![endif]--><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:DoNotOptimizeForBrowser/> </w:WordDocument> </xml><![endif]-->
macdabs
I can’t believe no one mentioned Tiger hair or body putty . It is easy to work with sands nice and lasts forever .
Mac
