Patching floor before epoxy-coat
marinebri68
Hi I'm trying to find a product I can use to fill some pitting in my floor and also level out some high spots and won't take a month to cure. I just moved into a "new" house and only have a couple weeks till I have to get all the stuff out of my old place so I don't have a month to wait for the patch to cure before I do the epoxy coating. The feathering out of the high spots will maybe be a half inch thick at the thickest point and it's maybe a 5x5ft area that needs to be done on top of the pits that need to be filled.
Is there something that I can get from someplace like Lowes or Home Depot that will do what I need? I am looking at the Quickcrete concrete patch that has a fast cure time but I'm not sure. I spent $500 on the Epoxy-Coat and don't want a huge spot in the middle of my floor that's messed up within a few months of doing it.
I'm quickly running out of time so any responses will be greatly appreciated.
Thanks
benwah
Crested Butte, Colorado
^^ Bam! Scotty hit it.
100% solids epoxy patching/surfacing products are much stronger than concrete. That is the way to go. Be sure to clean the area well and get rid of any loose or failing concrete in the area you will be patching.
M
marinebri68
Thanks for the replies. How long do I have to work with the above product before it hardens?
M
marinebri68
Ok I see it's free shipping, any idea how long it might take to get to northern WV if I were to order it now?
Garage Flooring
Grand Junction, CO
Thanks
Have a look at something like TL Patch Kit http://www.garageflooringllc.com/concrete-repair-materials/ we have a brochure there for you to look at as well. It has both an epoxy and an aggregate and is a great way to go. We stock the small kits and can ship one today.
Just re read the thread The other suggestion has an aggregate in it as well. Either way is a great choice.
M
marinebri68
So for the GarageFlooring site, is the 10sqft the only size you have for that?
benwah
1604 divided by your mil thickness will give you coverage rates for 100% solids epoxy.
80 sq. ft/gallon @ 20 mils
25 sq. ft/gallon at 1/16" (62.5 mils)
12 sq. ft/gallon at 1/8" (125 mils)
etc.
Garage Flooring
Grand Junction, CO
etc.
Just had a glance at the one Legacy had listed and I know for certain on my own these kits are an aggregate / epoxy combination
M
marinebri68
Is this an epoxy material on the GarageFlooring site or is it standard concrete patch?
Large Concarete Patch Kit spalled concrete, holes, and thresholds-- 12.4 Pounds
Sorry for so many questions, I just want to be able to get the most I can for the money I spend since as it is I was barely able to convince the wife that the $500 I've already spent is a good investment
Garage Flooring
Grand Junction, CO
It is epoxy and also aggregate. We don't sell vinyl patch. We do have straight epoxy patch. This is a better option. Legacy's as well and he is closer to you if time is important.
M
marinebri68
Ok so the 12.4lb unit should cover the 10sqft or so I need with some of it being almost a half inch thick? It's a high spot I'm trying to feather out and then patch the pitting. Does this need to be totally dry before applying? I'm needing to pressure wash the floor as well. If I need 2 large ones it's still cheaper than some of the ones I have seen so far. Is there shipping on top of it?
Garage Flooring
Grand Junction, CO
To many variables. Depth of hole, etc. If you order two, you can send an unopened one back within 30 days for full refund. Consider the volume of a 2x5 area with 1/8" deep issues vs the same area with 1/2".
M
marinebri68
Thanks for all your help Justin and I think I'm going to be ordering 2 large kits from you. Just curious if you know how long it may take to get to me here in Morgantown WV 26501 if I order it now? I'm going to assume to order won't be processed till Monday so I'm just wondering if it'll be by Friday if possible?
Also your example of a 2x5 area at 1/8" is that the coverage for the large kit?
HotRod68Camaro
Central TX
When using a patch kit, should i patch before any grinding/prep so that i don't have to do it over? Just trying to put together the entire process to make sure i save money on the HD tool rental.
Garage Flooring
Grand Junction, CO
Yes, get the order in today and you will have it by the weekend for sure
LegacyIndustrial
deerfield, IL
Ideally, the edge is "keyed" into the floor keeping the thickness around 1/16". It can be feathered to nothing but it's much stronger when keyed.
Several inches is not a problem. At a certain point it makes sense to look at a bag of 4K lb mix concrete, if over 5 or 6 inches. However, you can go pretty much as thick as you need to.
ColdBlackWind
Trigonia, Tn.
So by keyed in you mean to **** up to a 1/16" edge ground into original floor?
Is the 1 gallon kit after aggregate addition more than 1 gallon by volume? Any additives to make it flow? I am going to need a substantial amount if I try to repair my floor.
LegacyIndustrial
deerfield, IL
Yes. If the traffic will be considerable this is a good way to go. If normal garage traffic then feather it.
It's approx .5 gal of useable material once mixed.
The 2 gal units are the easiest to work with and are the best value, imo.
Rocktaco
Colorado
Would the concrete patch from Legacy be comparable with the Rust Bullet product?
ColdBlackWind
Trigonia, Tn.
Additives to make it flow? I am going to need a lot more than 2 gallons!
LegacyIndustrial
deerfield, IL
I can provide the liquids only, you can source your own dry sand. Best value
Send me a pm with cubic feet needed and I will work something up. Will need your zip code too.
Jaguar Fan
Park City for Ski Season; Las Vegas for Poker Seas
If you are concerned with being able to fully apply the product within the pot life, here is a trick that may help. I did this myself.
First, I used a product that was available at a local concrete accessories supply store http://apfepoxy.com/product-epoxy-300-flex#.VTe2u1VVhBd . In my case, I was just filling control joints, so application with putty knife & working it deep into the joint and scraping the top of excess material took time. I had so many linear feet of control joints to fill that I couldn't do it all within the pot life.
SO -- my solution was to take the epoxy bucket & put it into a larger tub filled with ice water. This slows down the cure to extend the pot life. I got an extra 15 to 20 minutes of pot life. I put the tub of ice water on a floor creeper to move it all around to follow me as I applied the product.
YMMV.
Garage Flooring
Grand Junction, CO
I have been playing with these numbers a little bit and here is what I come up with.
To ESTIMATE how much aggregate you need:
@ 1/4" you will need just less than 1.5 pounds/ Sq.Ft
@ 1/8" You will need just less than .75 pounds / Sq. Ft.
benwah
YMMV.
It's funny how many times a year I have to tell a painting contractor to do this because of the extreme desert heat. That's exactly what we recommend in this type of situation where a short pot life needs to be extended a bit.
ColdBlackWind
Trigonia, Tn.
Will do after I work down the high spots and see what I have left. Anybody ever use the big two disc, gas powered grinder that Sunbelt rents out? I think it is about a 300 pound machine. Was wondering what abrasives to use for the most aggressive cut.
