jw1968
Just getting going on 24x40 detached garage(footers and block foundation done). Installing 1/2" OB PEX for RIF heat, 2" foam. I am running 1" PEX for water(with PVC sleeve through the slab) and 3/4" yellow PE gas line (with riser pipe through the slab) that will both run through a 3"pipe in the footer, then about 30 feet under the #11 fill gravel. I am considering running the 3/4" PEX and 1" PE inside 1 1/4" and 1 1/2" PVC ($25)just to keep the gravel from potentially damaging them, or just digging a small trench (3"x3") to lay them in and covering with dirt before the gravel dump. What do you guys think??
