Simplytodd
I am getting ready to run the water line from my well to my new shop. The distance from the pressure tank at the well head to the shop is a run of 260'. For the most part it is a fairly straight shot with only a long arc over the length of the run. I have access to a backhoe so it will be buried 2'-3' underground.
Special considerations for my situation are about 150' of the run is along a fence line that will most likely have some serious root growth from both hard and softwood trees as well as some bamboo.
At some point in the future I will be needing to tee-off of the line to the shop to supply the future house that will be built adding another 300'-350' of line.
I will be driving a tractor over the buried line that weighs 5000+lbs.
As I see it if I went with schedule 40 bell mouth pvc I will have 16+ fittings just for the run to the shop. Lots of possibilities for future leaks. If I went with 160 psi PE in a 300' roll I will only have three. Less opportunity for joint failure.
What's yall's thoughts on the matter. Thanks in advance
