Pedestrian door in Metal sliding gate help
famhome12
I am planning on adding a pedestrian door within my existing sliding metal gate but want to make sure I am supporting the gate structure since I will be cutting into it.
Dimensions are: 5’4” x 19’6”
I have two designs in mind and have attached some diagrams that I made this morning.
In design (A) I would cut out the door within the top and bottom metal gate frame- leaving the frame in tact so person has to step over metal frame when going through the door opening.
In design (B) I would cut out the bottom 2” frame tube as part of the door and leave the top 2” tube in tact. This way you can walk through with stroller etc. For this design I would add two diagonal braces to the gate sections left and right of the door. I would also add a third wheel near the door on the bigger section of the gate to add support to the 2” top tube above the door which is essentially the only piece connecting the left and right sections of the gate.
sorry for the long description, I hope the diagram helps, I would please just like some advice on whether each design is ok, if I need additional bracing in either design, are the diagonal supports overkill, etc. I’m an 17yo doing this for my family on their money so I don’t want to mess anything up. I’ve been working with power tools and stick welding since I was 13 so I know I can do it. Any advice on the design aspect to make this safe and sturdy would be greatly appreciated and helpful. Thanks in advance everyone!32,6,on the 5th.png
tarbellb
Oregon
Hot take: Opt B - you'll pick up more height and ease of access.
But I think you'd want to run your diagonals opposite IE start at lower corners of new door and go up and out. \| |/
Also may need to reinforce the header spanning the door
3rd wheel is a good idea
GL
F
famhome12
GL
Thanks for the reply! As far as the diagonals… after doing more research, I wonder are they absolutely necessary since theoretically the 1” pickets are each adding a small amount of bracing? I’m posting an edited picture showing the pickets extending past the frame top and bottom which I think adds structural support, am I wrong? And since I’m not hanging the entire gate, I’m not really worried about sag? Im interested, could you explain your reasoning for why you would include the diagonals and why in that specific direction?
The door header reinforcing is a great idea, I’m thinking a steel plate at the top and bottom of the 2” header tube extending about 6” past the door on each side…is that your suggestion? If so, what thickness steel plate should I be looking at?
Thanks again for your response, it’s super cool that people are willing to help each out on niche forums like these 🙌
DGersic
DeKalb, IL
IMHO, your B design weakens the whole thing and I wouldn’t do it.
I don’t much like A either.
If I wanted a door, I’d frame in a door on the left side and make the moving gate shorter.
Muckin_Slusher
Abitibi
design B makes a super floppy noodle, even if you installed a silly huge member for the entire top of the gate.
Must maintain full frame around man door.
