Peel 'n Stick Roofing
QtheGenius
This weekend, I'm going to put some plywood over my outdoor kitchen structure. It's 6' x 20' with a 15 degree slope. I was planning on using 1/2" plywood instead 3/4" plywood, but then I remembered that my roofing nails would poke through the 1/2" plywood. So I started looking at peel and stick options.
I found some Liberty rolls that would work. However in all my research, I can't find out what prep is needed. I'll start with the flashing around all edges, then I was going to use some underlayment, then roll the roll on top. Would this be correct? Is the underlayment required? I just can't find information on the prep.
Q
QtheGenius
Was planning 1/2" staples for the underlayment. But if sealing is an option, I'd much rather do that. Under side of teh plywood would eventually get painted.
