I've read on here a few times about people using pegboard as a finished wall in thier garage. What I'm curious about is how the pegboard was stood off the insulation. I'm planning to run OSB or plywood on the lower 3' of the wall, a full sheet of pegboard above that, and finally drywall to take up the remainder.
Could I rip 1-1/2" wide OSB strips and use them to pad out the pegboard? Is that enough clearance that the pegs won't poke holes in the insulation behind them?
Is it a bad idea not to install drywall on top of the insulation? Am I losing a lot of the heat retention?
Thanks,
Ed
Thanks,
Ed
