Baclay9
To start, I have a 40x40x14 insulated (the white 3" vinyl backed stuff) steel building in central Oklahoma. Two 12' doors and a walk through that face the North and 1 8' door on the South side, all insulated.
I decided on a pellet stove after seeing lots of positive reviews. I ended up with a 50,000 BTU pellet stove. I had it in my head this thing was going to heat the shop up withing an hour or two from 40 deg to 65. I have obviously learned this is not the case.
I have a deisel tube heater that I have been kicking on when I turn the stove on to quickly heat the shop up to 65 deg. Then I cut the tube heater off and let the pellet stove run. Temp will slowly fall back to the 50's over an hour or so.
I noticed a bunch of cold air coming around my 12' doors that face the North so I went ahead and ordered Green Hinges to fix that.
Any other suggestions? Did I just expect too much? I am guessing if I let the heater run 24 hours a day so that the slab and all would warm up the shop would probably be alot easier to heat. I am only out there for a few hours 3-4 days a week though so this isnt really an option.
