Pellet stove?
Hillbillyhog75
West Virginia
Does anyone use pellet stoves to heat their shops? Building new garage this year and I am thinking about going away from wood stove to pellets. Does anyone have one they favor ?
Old Man Roger
Palm Coast Florida
I have no experience other than knowing someone who has one, but don't they take a long time to heat up compared to a wood stove?
If you're in the shop all day every day it's probably not a bad idea, but if you mostly need to heat the shop quick for a quick project, it's probably not the best idea.
Showkey
"MEMBER EMERITUS"
Wausau WI
Pellet stove hay days were...........when propane went to $4.00 per gallon.
Pellets have a cost and storage issue neighbor use to buy them in multiple pallets in attempt to get a better price, heater service and maintenance is constant.
As mentioned solid fuel heat for shop/garage have some problems and restrictions.
Pellets have a cost and storage issue ...
TRUE ! Buying at retail prices is ridiculous. If you live within 100 miles of a manufacturing plant, loading up a trailer would have a lot. But then you have to store them and keep them DRY !
b-boy
Buffalo NY
My Son has one in his house. During the Winter, it will heat his entire downstairs.
I agree with speaking to your insurance agent before you buy anything. I was looking at a wood burner option, and my insurance company said they wouldn't cover the building.
Kaizen
New England
Size is important. They efficiently burn a few handfuls of pellets. Now think of a fire that big. Gonna take awhile if it’s ten degrees to start. If you are out there all day maybe. Mine would go through two bags a day in low. That’s ten bucks at least a day. Much more then other heat sources. Add cost of stove, pipe, replacement parts and it’s not good. Just sold mine. Replacement part costs have come down quite a bit with overseas makers.
JOE.G
Eastern ( Catskills ) NY
I heat a 2,800 square home in NY, I burn between 3 to 4 ton a year at about $240 a ton. I run the stove pretty much from Nov to April and it keeps my whole house at 70 Deg with out a issue. I have the same stove since 2014. The biggest hassle is 2 to 3 times a year I do a really good cleaning which can get messy. Mine pretty much burns on low or on really cold days may burn at Half. If it is legal and okay with your insurance I would recommend one in your garage as Long as you plan on keeping it going all winter or can at least start it an HR or so before you go out there.
Jackfre
N CA
How big is your space? In addition to insurance, check the clearances all around on the appliance as well as storage space for fuel. I’ve seen so many places over the years where you look at the space, “oh, yeah, plenty of room.” By the time you are done you end up doing a doo-see-doo with the stove every time you walk through the room.
speed bump
Butte Montana
I had a pellet stove in my garage for a while. Considering the cost of pellets, the fiddly nature of the one I had, and the cost of a stove I wouldn't do it again.
930dreamer
Amarillo,TX and Stinnett,TX
I'm thinking that most pellet stoves have a zero clearance for install and can be direct vented straight out a wall and up. Friends i know like them until a new circuit board, auger is needed or the power goes out.
toyotadriver
Pellets aren't cheap any more. They used to be pretty cheap but, at least in my area, the price has gone up a lot. Propane is usually substantially cheaper..at least for me.
I looked into buying at a factory but as I recall, the min they would sell was 4 tons. I didn't have room to store them. I don't have a pellet stove any more. We liked it but didn't love it.
HVACR1
home
We used one in Vermont to heat a two story 1500 Sq ft house. The input was I believe 65,000 btuh. The space to non-combustible surfaces range from 18" to 30" depending on stove rating. At 40 lbs per bag and needing to keep them dry storage was a problem. You might need fresh air for combustion if you have a tightly sealed shop. It is imperative you keep the burner area clean, the pellets coat the burner "compartment" with a thick hard (1/8 to 3/8") carbon coating called "clinkers". The outer surface of the heat exchangers are easily cleaned, but again maintenance is paramount. If you do any wood finishing in your shop they are dusty, just pouring a bag of pellets in the hopper sends a dust plume in the air. I used a shop van when dumping pellets into the hopper and that wasn't enough to keep the dust down. Most use special double wall piping that can be pricey, depending on how far the flue run is. The piping is special because the stove operates on positive pressure so all the joints in the piping have a high temperature silicone seal to prevent flue gas leakage. They do put out heat when started in about 10 mins. Unlike a wood stove if you lose power they cannot be used as they operate on a 115 volt outlet. They require a special through the wall thimble to meet code requirements for combustible surfaces. If you have limited space the stove clearance to combustibles can me minimized through the use of sheet metal that is spaced off the wall I think 1/4". If you can store the pellets, don't mind the daily maintenance and dust, pellets might be the ticket for you. Just my two cents.
Bigshow0003
Vilas County, WI
HVACR1 hit the nail on the head. Although some love pellet stoves, there's alot of cost, maintenance, and storage that come along with it. We use one in a 4-season room. Per the stove manual I meet clearance requirements - but my insurance company wanted more. They told me they wanted 3' of clearance on 3 of the 4 sides (not wall side) and I got dinged with a surcharge. When I built my shop, they gave me a hard no for a pellet stove heat source out there.
I bought a mid to low end appliance so more maintenance for me. You would need an ash vacuum. My igniter has a 2 year life expectancy - so every other year replacing it at 100 bucks a pop. The circuit board is the most costly repair. Atleast on my appliance, getting to these things for repairs is easy.
Cost of pellets keeps going up. If I were to do it all over again, would have went a different route.
Big 70 B
My shop has 10 foot walls and is 36’ x 24’.
dies anyone know what size pellet stove I should buy to heat it
Showkey
"MEMBER EMERITUS"
Wausau WI
BTU‘s are BTU’s so it’s about the same if you have wood, pellet, Nat Gas, propane or electric. Yes, slight adjustment for heater efficiency.
It is very dependent on location ( climate) and insulation/air exchange. Winter climate reasonable insulation 1000 sqft would ball park with 45k to 75k btu heater. I heat 1000sqft with 45k Nat gas.
More important pellet are solid fuel……so there can restrictions in shop or garage.
Ball park estimation chart:
