Pencil grinders.
Bradc1989
Middle tn
I use my pencil grinder a lot at work. Mostly smaller carbide burrs to deburr smaller parts and cratex rubberized polishing wheels/points. I currently have a Chicago pneumatic grinder and it’s probably Around 8 years old. It’s showing some signs of wear like it has trouble taking it off unless I lube it at the beginning of every day And give it a little help on the initial use. What’s some other good options out there for these things? I’d say on average per week it might see a total of an hour and a half of use
DocsMachine
A lot of air-tool oils can polymerize- they dry up and get gummy. AT oil is really meant for the constant oilers that inject oil into the line on a regular basis, and even that's meant for tools that are used pretty constantly.
One thing you might try is running some WD-40 through the thing, and several times, to try and soften and blow out any gum that might have built up.
Then lube it with a good quality synthetic oil.
Now, if that doesn't help, and it'll only run after lubing, the vanes may well be worn down and not sealing well, or the bearings getting a bit loose. If that's the case, it's rebuild time.
Doc.
Jswain
Calgary, AB
Wd-40 might help as mentioned and it could take a few cycles. Spray in the air fitting with it upright and the trigger depressed, hook up air, run it, repeat let it soak in for a bit, hook up air, run it etc.
Don't use brake cleaner or similar as it can/will ruin some style trigger seats/internal seals.
Nothing will work as well as dismantling & cleaning, but always worth trying the wd40 first. I believe PB blaster or someone makes an air tool restore spray as well
