Pendleton (plombpire) brands show them here!
PROTO Challenger 1/4" and 3/8" drive SAE and metric socket set
as well as the 1/4" drive pieces listed here, this set also includes
1 ea 1212 3/8" 12 pt shallow
1 ea 1214 7/16" "
1 ea 1216 1/2" "
1 ea 1218 9/16" "
1 ea 1220 5/8" "
1 ea 1222 11/16" "
1 ea 1224 3/4" "
1 ea 1226 13/16" "
1 ea 1208S 1/4" 8 pt shallow
1 ea 1210S 5/16" "
1 ea 1212S 3/8" "
1 ea 1312 3/8" 12 pt deep well
1 ea 1314 7/16" "
1 ea 1316 1/2" "
1 ea 1318 9/16" "
1 ea 1320 5/8" "
1 ea 1210TM 10 mm 12 pt shallow
1 ea 1211TM 11 mm "
1 ea 1212TM 12 mm "
1 ea 1213TM 13 mm "
1 ea 1214TM 14 mm "
1 ea 1215TM 15 mm "
1 ea 1217TM 17 mm "
1 ea 1218TM 18 mm "
1 ea 1219TM 19 mm "
1 ea 1260D RHFT ratchet with thumbwheel
1 ea 1265 3 in extension
O
Trutest 3/8 pear head ratchet set
O
Here is a pretty much unused TAC set
Challenger 1060-1 1/4" drive RHFT ratchet
Challenger 1060D 1/4" drive RHFT ratchet
Fleet 13 piece 1/4" drive SAE Socket Wrench Set w/Original Box
Manufactured by Fleet Tool Corp., Schiller Park, Illinois U.S.A.
this set includes:
1007 7/32" 6 pt shallow socket
1008 1/4" 6 pt shallow socket
1009 9/32" 6 pt shallow socket
1010 5/16" 6 pt shallow socket
1011 11/32" 6 pt shallow socket
1012 3/8" 6 pt shallow socket
1014 7/16" 6 pt shallow socket
1016 1/2" 12 pt shallow socket
1008S 1/4" 8 pt shallow socket
1010S 5/16" 8 pt shallow socket
1012S 3/8" 8 pt shallow socket
1060-1 RHFT Ratchet
1065 3 inch Extension
Plastic Box
Fleet 10 piece 1/4" drive SAE Socket Wrench "Set"
this bunch of orphans includes:
1070 6 inch Flex Handle (Breaker Bar) * Drive anvil is loose. Detent ball stuck. *
1060 RHFT Ratchet * NOT working * possibly missing spring *
1063 6 inch Spinner Handle
Penens 17 piece 1/4" drive SAE Socket Wrench Set w/Original Box
manufactured by Penens Corp, Schiller Park, Illinois U.S.A.
this set includes:
1006 3/16" 6 pt shallow socket
1008 1/4" 6 pt shallow socket (* two each *)
1066 6 inch Extension
1070 6 inch Flex Handle (Breaker Bar) (* two each *)(* one has loose drive anvil *)
1060 RHFT Ratchet
Steel Box (* box is heavily oxidized *)
Not really sure where this one belongs...
Plomb empire 1/4" drive oval-head ratchet
Penens 1061 1/4" drive oval-head ratchet
Penens 1661 1/2" drive Oval-Head ratchet
^ "Cleveland 4, Ohio" - so.... there was another one as well... so those are... 1963 at the latest. The other one was a Vlchek ad. I've renamed the files "1963". Thanks. It's a common issue with images downloaded from the web.
O
Here's a speedmaster 3/8 set
Couldn't find a Vlchek pic thread so here I am.
Picked up these today. Appear to be Fleet or Challenger style wrenches marked Vlchek,
This is the thread I use to post my Vlchek finds although I certainly understand you posting your wrenches in the Plombpire thread.
Snaparxon
Closer to Idaho
I thought there was a Vlchek thread.I used the search everywhere function, titles only, and the word Vlchek and didn't see that. But then again I can't find the ketchup in the refrigeratoer door either. Thanks for the link.
Rather than trying to search, go to the Read Before Posting thread at the top
or, alternatively, you can check the list to see if there is a dedicated thread for that particular brand.
many brands are shown in the list which to not appear in the "sticky" thread post that @RTM cited just above by design - so you really need to use both resources.
  • Like
Reactions: RTM
O
Here's another artcraft set, all generic r tools
