Al Borland
- Joined
- Jan 20, 2016
- Messages
- 1,599
P.B. Blaster.
How do you guys apply the acetone/ATF mix to a rusted fastener? Anyone ever try one of these refillable aerosol bottles? https://www.amazon.com/dp/B009IY6IHS/?tag=atomicindus08-20
Seafoam Deep Creep seems to hold up better when used along with heat. The heat helps oil flow into the microscopic gaps to free up that stuck fastener.
But I'm another fan of Kroil. Got mine on the two for one deal. One can lasts a long time if you don't need to soak something big. For that I too use the 50-50 ATF and Acetone.
Anybody out there use an induction heater?
I just ordered the 32oz Sureshot to use for this.. or maybe break cleaner.How do you guys apply the acetone/ATF mix to a rusted fastener? Anyone ever try one of these refillable aerosol bottles? https://www.amazon.com/dp/B009IY6IHS/?tag=atomicindus08-20
JonnyMac, think about what you wrote. I know of no corporation in the world, whether it be in OZ or America, that gives away money. If they are willing to spend that kind of money for it don't you think there must be a reason. If something else were as good for 1/50th the price would they not use it. Here in America Kroil cost $53 a gallon which in my experience is a lifetime's worth of Kroil. Personally, I consider that to be dirt cheap. I've been using it since by dad stole a can of it and a Kroiller (their pump oil can) from work in 1970 and I'll be using it until I'm dead. I've been using the same gallon since 1980. It's true that I live in Arizona and rust isn't a big issue here but I'm originally from Pittsburgh, PA where it is and I've still got a quart left in the gallon I bought in 1980. Why are we discussing pennies?
This discussion happens here about once a month and I'm always amazed by the guys that refuse to pay for Kroil (which I feel is cheap considering what it does and how long it lasts) but have no problem paying for Snap-On. Seems illogical but that's just me.
I, ve never heard of this 50/50 mix before nor have I ever found kroil and this is what I had to use today.
You got to love the Gj I learn new stuff all the time
Thanks guys
I've seen this potion and variations of it on gun forums for years and it's still recommended. Google "Ed's Red bore cleaner".I thought that acetone/ATF study had been revealed as a hoax? Typing it now, though, I can't find anything to support that recollection through Google. So I could be off base.
That's why you should always wear nitrile gloves when handling acetone. Sure its dangerous but that's why there's ppe. I guess if you're a child about it you shouldn't handle acetone.
You actually want to wear latex gloves with acetone.
http://www.ishn.com/articles/90718-what-is-the-best-glove
I have had that list hanging on my bulletin board since 2009.
With prices (prob 2007 prices):
"The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and ****** fluid!
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
Also, another trick which I haven't tried yet is to heat the parts and wick candle wax into the joint. That's supposedly another slick trick.
How come a company doesn't sell 50/50 and just name it something?
