Teikas Dad
I saw this on another website....what do you think?
For all of you that are mechanically inclined..... Penetrating Oils Compared A study done by Machinist's Workshop magazine in their April 2007 issue looked at different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated. If the study was scientifically accurate, it turns out a home brew works best! Here's the summary of the test results:
Penetrating oil .......... Average load
None ..................... 516 pounds
WD-40 .................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ............ 127 pounds
Kano Kroil ............... 106 pounds
ATF-Acetone mix.............53 pounds
The Automatic Transmission fluid (ATF)-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
Stuff is high and low temp stable and is not combustible . . .
