PugetDude
Don't know if this has been posted before, a friend emailed it to me today; found it interesting:
Penetrating Oils
Machinist's Workshop magazine recently published some information
on various penetrating oils that I found very interesting.
Some of you might appreciate this. The magazine reports they tested
penetrates for break out torque on rusted nuts. They are below, as
forwarded by an ex-student and professional machinist. They arranged
a subjective test of all the popular penetrates with the control being the
torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oils ........... Average torque load to loosen*
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission
fluid and acetone. Note this "home brew" released bolts better than any
commercial product in this one particular test. Our local machinist group
mixed up a batch and we all now use it with equally good results. Note also
that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price.
Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can
also use ATF and lacquer thinner in a 50-50 mix.
*ATF=Automatic Transmission Fluid
Penetrating Oils
