arichardtx
Any experience or opinions on PENNTEK or PENNTEK products below (assuming all PREP is done correctly)? i.e. Best product on the Market, Typical product on the Market, Worse product on the market ... ?
Polyurea Base coat PB 200
penntekcoatings.com/pdf/techdata/penntek-tech-data-pb200.pdf
Polyaspartic Topcoat PT 300
penntekcoatings.com/pdf/techdata/penntek-tech-data-pt300.pdf
Also .. from my research on TDS specs to look at (in priority order)
1. Tabor Abrasion Resistance ASTM-D4060 (mg loss): considered to be the benchmark for durability when comparing one product to another
2. Adhesion ASTM D4541(psi): anything greater than 300 PSI usually means that the coating did not delaminate and the concrete failed instead
3. Impact Resistance ASTM-D2794 (in lbs): not sure how to interpret numbers like 160/160 or 80/40?
Not sure about others
Tensile Strength ASTM D412
Wear Resistance ASTM-D968 (litres sand/mil)
Flexibility ASTM-D522 (fails or passes)
Color & Gloss Retention ASTM-D4587 (Level 1, Level 2, Level 3)
Elongation ASTM D412
Compressive Strength ASTM D695
Tear Strength (PLI) ASTM D1737
Thank-you in advance!!
