Personalized Extension Cords
Richard D
Texas City, between Houston and Galveston
Extension cords are expensive, especially heavy duty models. I was looking at an aftermarket wiring harness(Ron Francis, Painless Wiring, etc.) and they have each wire labeled every 6" or so. I wonder how hard it would be to make custom extension cords(maybe just wire and you put your own ends on?). I know it would be costly, but it would be a long-run type benefit, preventing lost/stolen/accidentally picked up by someone else cords.
readhead
Durango, Co.
A shop I worked for in San Diego bought a lot of cords direct from the manufacturer. Molded right into the cord every three feet was "stolen from University Mechanical". I don't know if it helped but a few employees got fired for stealing company tools and pawning them. The cords id'd them.
ishiboo
Oshkosh, WI
There are lots of places that do custom lettering on wire/cable. It is expensive, but due to the process it's not necessarily impossibly expensive to do small runs. It will still fairly easily double the cost of the cord. Some are better than others - with many the ink used will wear off fairly quickly in use.
Heat shrink labels is probably a more economical bet.
bjcouche
There are panel shops that can do it for you. More specifically, if you order a 500 foot spool of SO cord and make up your own extension cords, this might be an option. The printing is done on the cable as the cable is fed off the spool. The sources you mentioned are automotive, think industrial panel shop. Maybe someone else will chime in and have a source.
Me, I just buy bright pink cords, no guys steal them. I knew an electrician that did that, bought pink screwdrivers, and he always knew which one was his...
Brian
krandrew
Edmonton Ab
You can use dual wall shrink tubes with the hot glue inside it. Just put a sticker or label behind it. Works nicely on larger cables
gtcs
nm
At work we order all our cords HD 100' hot pink with property of xxxxx electric printed every foot
We order them about 20 at a time, and the printing is free
Rt jam
A cheap and easy solution but not as permanent is a label maker. There are special labels for small gauge wire that wraps around and the final lap around is a clear section to protect the print.
James-W
Southeastern Wisconsin
A buddy of mine used to make his own extension cords. Before he would put one of the ends on the cord, he would type his name on a sticky label and stick it on the cord. Then he would take a piece of clear heat shrink tubing and put it over the label and then shrink it with a heat gun. The heat shrink tubing would shrink and tighten around the label and his name would be clearly showing. I suppose if someone really wanted to steal the cord, they would do it and remove the heat shrink tubing and the label. But it kept the honest people from stealing his extension cords.
555
Nomad-Arkansas & Georgia
I use to make all my own extension cords. I'd get SJ cord from the electrical supply house and add the male/female ends. I didn't mark them as I was the only guy with that type of extension cord.
RVDan
North America
Acetone will take the ink off.
Of course the scrap places here don't care if it's stolen, they're required to take a copy of the sellers ID, but don't have any requirement to try to track down the previous owner.
ranger302
RALEIGH NC
The Lowes near me will do custom cords with anything you want printed on them. I think the min order is like five or so.
slowzuki
Eastern Canada
Place I worked just spray painted stripes on them while they were coiled up. Paint wore off about when the cord was done.
LXCam
There are a couple companies that will heat stamp whatever into the sheath so even if the ink goes to hell you still have the indentation.
I did the same thing with my contracting business. The guys hated the pink cords, but I never had another one ripped off again. Job site twist lock adapters became an issue as well, so I cut V shape notches into the ends.
I'm looking for some that shrinks 75% instead of 50 so I can slip it over the ends of pre-molded cords.
No one makes shrink wrap that will reduce far enough to go over a cord end and fit snugly to the cord. Least nothing I've ever found.
I can't remember who I used to buy ours from but here is a place that prints custom labeling.
http://www.jhlindustries.com/customcords.php
bwringer
Indianapolis
You can get clear shrink tubing in 3:1 and 4:1 shrink ratios. Most shrink tubing you find on the shelf is 2:1, so you have to order it from McMaster-Carr or wherever.
This might take some experimentation -- the higher ratio shrink tubing ends up thicker and more opaque, so anything under the shrink might not be as legible as you'd like.
You can also get custom printed heat shrink tubing in 3:1:
http://www.heatshrink.com/content/custom-printing.asp
Tyberius
Wilmette, IL
I usually melt my initials into the ends with a soldering iron.
ETA: Usually do this with any plastic tools and cases
shocksandstrutz
Wentzville, MO
I know this is a different industry, but in the substation and transmission world, all new installed copper or cables are laser etched (at the factory produced) with a serial number and those numbers are regestered to a buyer........many of scappers have been locked up for stealing and trying to scrap. There is a coting or something around it that the scra yards use to verify.....its been a big deal. Now this doesn't work if they melt it all down.
I like the idea above about making your own and stamping a washer and putting it on before the ends. I'm stealing that.
Firebird 1
Maryland
We used to buy our cords from milspec. with company name imprinted, Didn't cost that much but we bought case lots. The name did wear off but it was printed about every foot so there always was some of it still there. These cords did seem to go bad at the ends prematurely though.
