Well the last few days been pretty good, I got the generator running, fenders fit and some other odds and ends finished.
The generator wasn't a big deal, I had a minor wiring issue that I had to complete and the almost cost of a transfer switch. I couldn't remember where this one wire went to but after some research and thinking I figured it out. The guys at Martin Diesel were as helpful as always. Paul is usually my go to wiring guy but he's out this week so Mike helped me out, which he builds them so he knows whats going on too. There are 3 10 gauge wires that run to the sleeper from the electrical box on the bunk, a black, white, and green wire. Well, I knew where everything went except the green, I figured it was a neutral but if it would have been neutral it would have had a ring terminal on it, when I disassembled I did not cut wiring, I undid it and removed it the same way it went back in. Well, I found out through the transfer switch in the bunk that the green wire was actually hot wire #2 for the transfer switch. SO, after hooking that up, the bunk came alive, I now have everything working inside the sleeper and ready to go there. I still have the fridge to install but thats a few minute job.
Everytime I service this generator I forget to fill the fuel filter, so the only way to get the thing running is to keep holding the start stop switch for less the 10 seconds several times. The fuel pump is electric and will run for 10 seconds, then the generator will turn over. Since I don't like to crank on the starter anymore then necessary it would sometimes taking me several minutes to get it running. Well, Mike at Martin asked me why I didn't have a priming switch for the fuel pump, apparently a year or so after mine was built they started putting a 3rd switch in the electric box and that was only for the fuel pump, he walked me through hooking it up, it was a matter of 2 wires about 6 inches long, and 1 spring loaded peterbilt toggle
. So now I have a primer switch to run my fuel pump, no more start stop switch holding.
The wiring and fuel lines to the generator came out a lot better this time then the original time I did the install. I think the first time I was just in a hurry to hit the highway and didn't take the extra finess to make it nicer. this time went really good and came out nice.
Well, after my dad and I straightened the hood side things went smooth from there, we pulled it back out that 1/4 inch and man it was a good thing I was able to do that, otherwise these fenders would look queer. I got both fit last night and they are going to a paint shop today to get painted, I'm then going to work on the front bumper and finish up some odds and ends so the truck will be done when the fenders get back.
here are a few shots of some of the wiring in the frame, I've got everything ******* and tight so this will be how its rolling. I will tie up by the air line union today or tomorrow, I have to find an 8 gauge wire connector so that I don't have to cut the wiring anytime I need to remove my light bar.
