sands35
So, getting ready to install PEX for detached garage radiant floor. 26x32 footprint on the structure.
Since things are moving fast, I needed to buy 250' rolls of PEX rather then order 300' rolls. Oh well.
Anyway, I have 4 loops at 170, 169, 167 and 163 (at least on graph paper). The 163 loop services the area in front of the garage door so that might work out better.
Sorry, not at a place where I can scan in the drawing yet. Perhaps later today.
I'll be doing the install on the 8th and 9th. Concrete pour is the 10th.
Question - is the ~5% difference in loop length OK? (I plan on laying out the pex and likely will need to tweek it a bit to get is closer to even loops)
Planning on vapor barrier then 2" XEPS foam. Pex stapled to the foam then wire mesh. GC recommended the mesh on top of the pex to hold it down during the poor.
Pex is cheap...in my experience you can never have too much within reason.You should also should think long and hard about putting in rebar on 12" centers....mesh is a total waste of money!
