pex design - concrete exit
gogolf0401
West central MN
Have a nice looking implementation for how your pex comes out of the concrete?
Did you use PVC elbows for organization? Something else?
Looking for ideas on how to support manifolds and pex before/during a pour where there is no wall yet.
ransil
pa
I installed a 5 foot unused piece of pex for a temp sensor .
I used strut channel about 6" above the concrete top yo secure the conduits
Sent from my SM-G920V using Tapatalk
G
gogolf0401
West central MN
Did you drive the strut channel into the ground and then run it horizontally 6" above the concrete? What did you use for conduit, just PVC elbows? Pictures?
dcg9381
Austin, TX
Wire above slab level connected to the slab perimeter and tying them into the rebar mid-slab below slab level. You basically stabilize them. If they're mid-slab, they'll have an exit point somewhere and hopefully you can stabilize the run.
When they pour, you can have them adjusted as long as someone is paying attention. You want to be present at the pour anyway.
Jackfre
N CA
Ya, probably. Wondering how folks support these mid slab.
Sky-Hooks! Or you could box in the small area where the sweeps are coming up. Use some grade stakes to support the tubing temporarily within that area. After the slab pour pull the forms on the small boxed area, line things up as you want and pour it.
G
gogolf0401
West central MN
Similar to post #2 but instead of letting your pex run on the ground, put in pvc conduit pipe. Then run the pex through that
You're saying to run conduit all over the floor where the pex is going to be and then try to push the pex through the conduit after concrete is poured?
