Pex Expander?
AEAdam
SE PA
Double the diameter, and you increase the volume by 4 times!
If I’m not mistaken, the fixtures limit the flow. So you won’t get an amazing fire hose shower if you run 1” PEX to it.
Running 3/4” to a shower or especially soaking tub can help tho. But you gotta check your min bend radius. Dumb to run big tubing and use elbows. I’m not a plumber, but I think there’s a difference between pressure and flow rate. Technically I don’t think you lose pressure with an elbow but you do lose some flow rate.
Theres a lot to this, is the point. Just because you have the tool to make the connections doesn’t mean this is a cake walk. You either need to know everything a plumber knows by reading, or maybe it’s better to hire a plumber as a consultant, pay him to help design your system. I think if you do all home runs with 1/2” PEX, that’s probably a simpler starting point, followed by sub manifolds. Traditional branch circuits are probably the hardest to design properly followed by recirculating systems
Junkman
Northeastern CT
As a "rule of thumb" when plumbing, a 90-degree elbow is equivalent to adding 8' of pipe to the system. Pressure and volume are two different things. A waterjet can cut steel, but a hose will only get it wet. A fire hydrant supplies water, but the piping to the hydrant determines the volume of water supplied. According to the NFPA, all fire hydrants should be color-coded by the volume they can deliver.
KnurledNut
n/a
Truth. A lot of issues don’t surface until after its done. Like the common shower rise problem from installers not knowing to run a 3/4 drop to the tub spout.
