Pex for air line?
ADSR
There's a few AL-PEX jobs on here. I plan to try it with regular pex and only 125 psi.
dfiler2
NW Minnesota
The manufacturing plant where I work has used PEX for air lines for the past 25 years. We are a MNSHARP company, which means OSHA has agreed not to make unannounced visits, there are 35 MNSHARP companies in MN that have qualified for this program. I point this out because I know for a fact that PEX is approved for use as airlines and is very safe. I understand using black iron as it makes for a very neat install. I do have concerns about using AL- Pex for anything.
er3456df
Just curious- why? I've never used it, but it seems like it should be as good or better than regular PEX at pretty much everything (aside from maybe flexibility).
dfiler2
NW Minnesota
I was introduced to AL-Pex about 20 years ago,my concern at that time was that you had two different materials that would expand and contract at different rates. I felt that the possible long term problems were not worth the risk. As it turns out most of the problems and failures of the product were caused by electrolysis where the aluminum came in contact with a dissimilar metal at the fittings. I think it is easier to do a neat looking install with the product but given its current track record I am just not comfortable using it.
Understand this is just my opinion and I realize millions of feet are in use as air lines with no current problems.
It seems some people have PEX and CPVC confused, they are very different products and I would never suggest using CPVC for air lines.
akdiesel
Wasilla, AK
Pros to PEX-AL-PEX are faster installs, less connections, less initial costs and easy to make modifications.
Cons to PEX-AL-PEX are that it will not absorb the air temps like metal pipe to help drop out moisture, can have low section in straight runs to trap moisture, and if not installed correctly can look and function bad as just mentioned.
So if you have a small shop and are to overly concerned about moisture or live in a high humidity location than PEX-AL-PEX is a great choice.
