Pex/hose/tubing cutter?
posaune
Collinsville, Connecticut
After a long time away from home (and GJ), I had a project to do around the house today and decided I needed one of these tools to make a clean, square cut in pex. Long story short is that I was disgusted by all of the expensive Chinese tools at Lowe's and HD, so I went home and got nothing done.
Is there a recommended tool in this category? I'm not completely against Chinese stuff, but I do want something relatively high quality. I won't be using this much, so the $100 ones are out.
greasemonkey44
memphis
i used the red rigid cutters; they were dirt cheap and iirc us made
they lasted for hundreds of cuts and lots of abuse
P
posaune
I looked at the Rothenberger ones online and they looked interesting, but I'm hoping to find something close. If not though, I lean toward those. Unfortunately, everything I saw marked Ridgid was made in China (though it looked decent).
Amazingly, Lowe's has one (the brand was Superior Tool maybe?) that is made in the US, but it seemed to be more poorly made than the others.
I haven't seen the Milwaukee yet, but I'll look for it. Any thoughts on Lenox?
MrMark
Southern Cal.
I bought a Klein one in Home Depot, cheaper than the Chinaman ridgid. It's probably Taiwan as it is not marked on the tool. But, it seems to be a good tool. I've used it quite a bit and like it.
luvit
i've cut a lot of pex and can't recall issues with square cuts.
ive used typical "**********" tube cutters, but i more-so appreciated carrying the size of the following cutter..
P
posaune
Well, maybe I shouldn't be worried. I am planning to use SharkBite fittings or the equivalent and it looks like the cuts need to be pretty square to seal correctly. Maybe I'm wrong though- I've never even *touched* pex before.:eek:
Lol. Well yes, and I'd love to have them, but that would more than double the cost of the project.
luvit
you're gonna love pex, if you have good crimpers
and no, square cuts are not required.. there are enough barbs and those copper crimp rings really make it water-tight.
i've made hundreds of crimps in a few homes and not a single leak on any crimp
also, i purchased these crimpers because at the time, pex crimpers were $100 per crimp size..
i bought these crimpers for $60, which covers all pex sizes.
one crimper does 1" pex, the other crimper does the other sizes.
http://pexcrimper.com
luvit
nevermind, my post, above, may be irrelevant to sharkbite fittings.
sharkbite looks pretty cool.. i wonder how they compare in cost to regular crimp fittings..
Big-Foot
Midlothian, TX
Crimp fittings are cheaper than SharkBites, but not reuseabe like the SharkBites are. I gave up on soldering in close spaces anymore because they pretty mch have done away with lead solder and the replacement stuff ***** the big one (doesn't sweat well).. I use almost all SharkBite or the plastic versions now...
Provincial
Near Salem, OR
I use a hose cutter similar to the Home Depot model only mine has blue handles rather than red. I find that the hose cutter, because of the sharper blade, cuts cleanly and square on 1/2 and 3/4 pex. I haven't tried it on 1" pex, but I'm sure it will cut that just as well as the smaller sizes. I use it on radiator, heater, and air hoses, plus the black nylon tubing for truck air brakes. It works well on all of them.
