How many plumb cold water lines IE sink toilet, etc. underslab before floor is poured??
H HiItsMeJimmy Well-known member Joined Sep 1, 2012 Messages 66 Oct 14, 2012 #1 How many plumb cold water lines IE sink toilet, etc. underslab before floor is poured??
K KPSquared Well-known member Joined Aug 18, 2010 Messages 2,750 Location Wetaskiwin, Alberta, Canada Oct 14, 2012 #2 In mine and some other shops I've run 2" black plastic water line to all the possible locations and then pulled the pex through later.
F Fastback Well-known member Joined Oct 5, 2010 Messages 518 Location Indy Oct 14, 2012 #3 Its kinda common, like KP mentioned, pull it through some conduit or something where it transitions above the slab.
M matouse3 Well-known member Joined Feb 19, 2012 Messages 289 Location Mid-Michigan Oct 15, 2012 #4 KPSquared said: In mine and some other shops I've run 2" black plastic water line to all the possible locations and then pulled the pex through later. Click to expand... Thats what I did. I just put elbows of the appropriate size for sewer and water lines through my footings before the pour. I likely won't get to them for a while, but they needed to be 40 or so inches down, so they are there when I get to it.
