koditten
Has anyone purchased thier pex tubing from Menards? My question stems from the fit of connectors to tubing. The 1/2" pex to 1/2" NPT fitting was rediculously sloppy. Even with the connector still in its plasic bag I was able to slide it into the pex with no effort and wiggle it around. In all my years of dealing with all sort of hoses I have never been able to slide the barb into a hose without just about blowing a nut to get it all the way in.
The little high-on running the plumbing department assured me that this was normal and I would have no problem getting a proper pressure check once I put the clamp on the tubing. I could not bring myself to believe him.
Anyways I passed on these fitting and opted for compression fittings. These fit like I am used to and looked to be much better quaility.
Has anyone used the compression fittings vs the push-in barbs with hose clamps. I like the compression fitting much better, but of course they are 5 times as spendy.
Any feedback with be appreciated.
Thanks
Kirk in Mid-Michigan
Thanks
