I will be running some PEX water supply lines under a new slab and then up through the slab into a new wall. Reading the code book says that PEX needs to be protected from abrasion when penetrating concrete in this manner, but it does really state with what.
I have done some searching and have seen foam wrap with tape, foam sleeves, and IPS 83400 Pipe Sleeving. For those who have done this what did you use?
I do plan to run pre-insulted PEX for the two hot water lines, and just regular PEX for the cold.
