PH3050 adjustment question.......
Buckgnarly
VT
So picked up a PH3050 used, just tried it out and was bummed at first. Seemed to lack power, but after messing with the red dial at the air inlet the thing hit like a freaking BEAST with about 1/2 the recoil of my IR.
Did not get to play with it much after that, but for those who have them, are the little lines the power settings, and is it the line that is facing forward on the grip? Hope that makes sense, really impressed with this thing so far, just want to make sure I know how to work the thing.
ToolGuy89
The lines on the dial are the power settings and the lines align with a dot on the gun itself.
blacK20
Yep the lines on the red dial are the settings. One line is the weakest and four lines is max power. The setting on the dial will line up with a dot on the inlet that the air fitting threads into. If you listen closesly you will hear a click as you turn the dial.
