jrlp
Well, I'm in need of an air hammer, and have read probably 80+ threads on this forum in regards to the PH3050. I was almost sold on it, when I came across the IR 118max. It's quite a bit bigger, 1.6" longer than the SO, and 1/2" longer stroke as well. They both have the same BPM.
The 118 is a lot cheaper, tooltopia has it for around ~125 for the kit with blow case and 5 chisels. I'm sure the chisels are useless, and I was planning on buying a few Old Forge goodies to go with it.
Is it possible IR's new hammer is beefier than the SO? I plan on using it for panel ripping, bolt shearing, balljoints and suspension bushings on everything from mid 60's cars to 1ton and a few medium duty trucks, driving pins on small hydraulic cylinders, etc...
The first use I have for it is shearing lots of sheet metal and a few hundred bolts keeping my totalled '97 12v cummins together so I can get the body/bed off the frame to get the drivetrain out. I plan on using it a few times a week. I realize the 3050 is the standard all other .401" hammers are judged by, but on paper the IR looks to be real nice.
For the lazy:
PH3050
IR 118 Max
Any input on the matter?
For the lazy:
PH3050
IR 118 Max
