Phase Converters... Help
Jim Johnstone
Brantford, Ontario
What's the consensus on using a VFD on a machine with multiple motors? I have a machine in my garage with 4 motors in it, all powered by a single input that gets distributed in the machine's electrical cabinet.
Would that work fine if the VFD was sized for all the motors combined, and if I wasn't running the frequency up and down?
larry_g
oregon
So if I was using a rotary phase converter you can bypass using a single phase motor to spin the 3 phase one with capacitors and other stuff?
Did you follow the link that I gave you in post #5 here? It has the answers to your questions.
lg
no neat sig line
454ragtop
Carver, MA
Not recommended. 1 motor per VFD, with no switches between the motor or VFD. I put a VFD on a Van Norman #12 mill for the spindle, and swapped the 1/4HP feed motor for a single phase motor to complete the conversion to single phase.
HTH, Jim
Jim Johnstone
Brantford, Ontario
HTH, Jim
Sounds good, I will stick with a RPC for this machine then.
