Home Depot had quite a few of the Phillips T8 replacement LED tubes for only $9.97.
I am not sure if they will work in T12 fixtures but most LED tubes work in either.
I will add a photo later
You can get 10 packs online for $90 so you basically get one bulb free. These bulbs are awesome IMO. I put them in the 3 bulb HD shop lights that were on clearance a while back and they are super bright.
They do only work with certain instant start ballasts (I think pretty much anything though... There is a table on the Philips site) and the fixtures need to be T8. THESE WILL NOT WORK WITH A T12 BALLAST!!! NOR WILL THEY WORK WITHOUT A BALLAST!!!
These have been in store for a while but were "no home". I bought some a few months ago but had to search the overheads for them as they didn't have a spot on the shelf for them yet.
I picked up 4 bulbs to try to replace some "aging" T8's (less than 3yrs old and dimming). They are marginally better, I can see some difference in the lighting but not a whole lot. The old bulbs were Sylvania 5000k's.
Not a bad price to replace dead bulbs with though. I will probably buy some more to replace the other dimmings ones.
do it!!But my 28 x 32 backyard garage could use 28 4ft bulbs to replace the flourescents. This batch would still be shy by a few bulbs. What says the garage gang?
These are now $5 each delivered. I know they are made in China and they are cheap, because they are from China. (See, doubly bad.)
http://www.ebay.com/itm/17170620721...9255-0%26rvr_id%3D1152776501937&ul_noapp=true
A warning about the ebay tubes - they are single end powered. That means you might (probably?) have to get new lamp holders AKA tombstones. I think that most fixtures are dual end powered. So you have added expense and work. I got these from amazon:
https://www.amazon.com/gp/product/B012AHPPTQ/?tag=atomicindus08-20
They are dual-ended powered and you must bypass the ballast (easy). They are also 22 watts and 2400 lumens. I replaced four 32 watt fluorescent tubes with three of them and I think my garage is a bit brighter than it was.
