Phoenix bleeder question
Garagebound1
Wolcott, NY
I've used my Phoenix reverse bleeder with good results but I have a question I haven't heard answered. I built a whole brake system on a home built car and with Wilwood components everything worked good. I had a Land rover that blew a line. I replaced all of the brake lines and bled them by gravity, also a Motive and then a Phoenix. I had pedal go to floor first pump them lock wheels second pump. I ended up taking it to a dealer and they replaced master and and unit. My question is, is the Phoenix ok to use with and units? I know there are valves in the and but I'm not sure how they operate. Also not sure if the gigantic bill was legit either.
Schurkey
Reverse-bleeding is a fine practice...IF THE BRAKE FLUID HAS ALREADY BEEN FLUSHED so that the fluid in the system isn't contaminated.
IF (big IF) the fluid in the brake system is contaminated--and it is unless it's been freshly flushed--the worst fluid is generally in the lowest spots--the wheel cylinders. Reverse bleeding pushes the worst fluid back through the ABS valves, combination valve/proportioning valve/holdoff valve, and into the master cylinder.
What does that mean?
What is an "and unit"?
Wild guess--the system emptied, the master cylinder got air in it, and should have been bench-bled before screwing with the rest of the system.
G
Garagebound1
Wolcott, NY
Damn auto correct. They replaced master cylinder and ABS unit. That was after I replaced every brake line. So I'm not sure how there could have been anything in system. I was wondering if the Phoenix would have a negative effect on the ABS unit.
