Picked up an Arboga Maskiner drill press
chickenfarmer
I've been needing to replace my generic Taiwan drill press for a while and I've been watching for a sweet deal on a causing or powermatic with variable speed. But I saw this beefy guy on auction and figured it was worth a try for $250.
I had never heard of Arboga Maskiner but apparently they are pretty tough. It's made in Sweden and is all gear drive so I have high hopes. If it even turns on, I'll let you guys know
If anyone knows where I can get a manual that would be appreciated
tarbellb
Oregon
Gearhead ie no belts
Will drill through just about anything
Well respected name in drill presses
Did real good
dutchgray
Dorset. England.
Very nice, the typical 4 speed gear box with 2 speed motor and its got a power feed. High quality drill, a good one of those might fetch 2K here.
dr_clyde
Holland, MI
Arboga makes a very high quality drill. You got a screaming deal.
Once you go gear head, you’ll never want to go belt drive again.
C
chickenfarmer
Thanks for the replies, and the link!
When I first wired it up and bumped the switch it had a terrible squeal from an upper bearing, so I thought it would be a rebuild project. But when I put the drain plug and some oil in the gearbox it quieted right down. Not sure who took that out haha. I had some 7/8" holes to drill and it loved every second of it. It's a monster, and I'm excited about having reverse too
TjoFrasse
Sweden
That's a great find! Those machines are highly sought after and would cost many times more here.
MO-Iron
SW Missouri
I have a model GM 3512 in my farm shop. I was in the right place at the right time and have less than $100 in mine.
I was already setup with 3 phase and have found it to be a great machine.
C
chickenfarmer
I am wondering if the model numbers mean anything, will you post some pictures of your 3512? I am guessing the 35 means 35mm max recommended capacity, but not sure about the second 2 digits
