I finally got the Champion vr5-8 that a friend of mine needed "out of his way"relocated to my garage. Now since I'm a total novice at compressors I need help on how to get it working. First on the list is a 5hp single phase motor, currently has a 3phase, So I will be busy searching for a 5hp 1740 rpm 1-1/8" shaft. From what I can tell I will also need to get some type of starter switch? Is that correct? While I was turning the pulley I also noticed that the intercooler line has a whole in it
Is that something that can be soldered? or am I best to get a whole new pipe? It also needs a air filter and housing but I only have come across the type that goes straight up. It seems this one angles downward so any help on parts for that would be great as well. That is about what I can tell from visual inspection. What test if any are there to test the pump? or any other inspections that I could do in my research? Looking forward to working this project through with any help from all of you experts!!!
Im thinking they are not the ones I need?
