Picking up an angle grinder, need some input
tw33k2514
Chicago
T
tw33k2514
Chicago
The Bosch 1806E is the one I'd get today.
Mine is the old model 1301 and it's been an excellent grinder.
Spend the couple of extra bucks and pick up the Magnum
http://www.amazon.com/dp/B00004TI18/?tag=atomicindus08-20
Last time I looked the Magnums were still US made and a heck of a grinder.
Otherwise I would skip the Dewalt, they are kind of blah for the money you pay.
I am intrigued by both options. I would spend the extra money on the Bosch if I could convince myself that I need a 6" grinder...but idk...
T
tw33k2514
Chicago
Does that Milwaukee have a paddle switch? ^ ^ ^ ^
I hate paddle switches.
Yes it is a paddle. All I have ever used is paddle type grinders though.. So it does not bother me.
Really all I will be using this for is cleaning up welds, and cutting metal. I am sure I will find other uses along the way, but for now I think a 4-1/2" grinder will suit my needs.
Merkava_4
Clovis, CA.
I don't know how you guys can stand paddle switches; you gotta constantly squeeze the damn thing to keep the grinder running.
dustin19
defiance ohio
get a old 9 inch full metal body one at a garage sale this summer for 5-15 bucks i usually see them at auctions and and stuff and they usually always work and are built tough and have real power
Rickster
SE PA
I know you wanted to go with the whole high power thing, but there a few other things to consider. First of all is the weight. If you're going to use it a lot for grunt work like grinding gunk off the chassis of old cars I prefer the HF cheapo light-weight ones. When they burn out I just toss them in the trash. Also, consider the cost. It's not uncommon to see guys with two angle grinders each with a dedicated job; cutting disc or grinding wheel. That way you don't have to stop and change disc's in the middle of a job. If this is your first one, go to Home Depot and grab & hold a few models to see what configuration you're comfortable with. I found I liked the trigger handle feel of the B&D model at HD.
pirana
Wild Peach, Texas
More than a $100 but we have a Dewalt 4-1/2" grinder at work that's 13 amps & has taken serious abuse as it's used in a steel fabrication shop everyday. You can't stop it by bearing down on it if you try. On the other hand, I bought a 7 amp Dewalt at Lowes last year that crapped out after 4 months. I want a Metabo now.
Red Green
South Central Michigan
I agree with Rickster. :thumbup: I have a cheap grinder from Menards with a wire wheel on it and on I have a dewalt for grinding. I have a older model of the Dewalt you linked to I have been happy with it. I can't comment on the new models.
1320stang
Edmond, OK
Uhh, just holding the grinder keeps the paddle down, how do you hold a grinder? WIFF UR TEEF?!? :lol_hitti
I have two Dewalts, but I plan on getting a Metabo for my next grinder.
Stick Figure
Omaha, Ne
ever had a cut off blade crack, then catch and rip the grinder out of your hand? I have ... w/ out the paddle that thing bounces around like crazy until you can unplug it. Now i won't use one that doesn't have the paddle switch.
MotoDave
Ventura, CA
I think a 4.5" is definitely what you're looking for. I got a Bosch 7" angle grinder for stupid cheap off ebay, but it is huge! Definitely too unwieldy to be used for notching tubes, cleaning up welds, etc.
jwith68
EC Missouri
I bought the Milwaukee 6148-30 a couple months ago to replace a Porter-Cable that I let the magic smoke out of. I haven't used the Milwaukee a whole lot, but I am impressed from what I have done with it. I'm not a little guy, and it is all I want to try to hold onto with a 3" cup brush. The paddle switch works great, much nicer than most. The no-tool guard adjustment is very nice as well. It is, unfortunately, not US made.
That $79 shipped Amazon price is a great deal - couldn't find one for less than $99+shipping a couple months ago, then wound up getting one from an eBay seller for ~$87 to my door.
Monte
Germany
Aren`t the lower priced Milwaukees made in Mexico ?? Or already china ? What about the sawzalls ?
T
tw33k2514
Chicago
Defiantly some good points. I personally will not be using the grinder for extended work like that so weight is not really an issue for me. That and I am not exactly a small guy... And if I ever do work where I need to switch disc's I will probably just go buy a cheap one for the less important job.
At the moment though I am still heavily considering the Milwaukee Magnum.
