Hello, I am building an 16' X 24' Accessory Structure (Cabin, but don't say Cabin) up North (Northern Michigan) on a Pier Foundation this summer. This building will be Canti-levered out over a rolling hill. So, grade is about 4' lower at the back of the Cabin than at the front. My plan was do 12" Concrete Piers for all of this (Sandy Soil), and I am looking for specs to do them. Rather than stopping all of the piers slightly above grade, and add posts to get up to the floor my plan was to pour them/form them to the finished height I need for the floor. At the back of the structure (16 foot wide wall) will be 3 of these piers, then 2 eight feet away, then 1 in the Center ten feet away (for ridge support), 2 more sixteen feet away, 3 at the front wall, and 3 more to support the porch for a total of 14 holes/piers. I attached a simple plan view sketch (sorry, it's a little light) to illustrate that last sentence.
Anyone have any insight or specs to accomplish this (rebar mesh, single rod, pattern of rods, which pier needs it, etc.)? Do you think I should connect any of them via footer? For the taller 3, I plan taper out the bottom of the hole a bit more, and of course pull the form up off the bottom some. Lastly, should I bias the piers to the inside of the footprint of the building to help prevent water from sitting on the tops of them or just center the brackets?
Cooter
Cooter
