pin style lock
Those are only meant for use with a socket that has a hole drilled through the side, such as an impact or power socket (used in assembly line work).
Chrome sockets with detents inside the square may get stuck on it and not come off in some cases.
L.Cheapo
I'm looking at this and it mention "pin style lock for production applications"
Can someone explain what it means ?
https://www.amazon.com/gp/product/B0042T8Z1Q/?tag=atomicindus08-20
I only know of ball retention, just by pulling and pushing the socket in.
Can this pin style be used with a regular socket ?
Thanks in advance.
Pin style is more convenient on a tool that only really ever uses one size of socket, such as an assembly line worker might. The pin locks the socket to the anvil of the tool, and can be a PITA to remove if you need to do it regularly. You need to push the pin in with something else.
Most of us prefer the standard spring loaded ball type, to easily and quickly change sizes as needs dictate.
Strouty
Southern Maine
I think it stands for Pain In the Nuts, they are only nice if you don't want to remove the socket. I use them on impacts when I work on towers. The sockets really need to have a hole in them to do much good.
WhiskeyRanger
As mentioned, they are for production work. On the other hand, I do have a few used I.pacts that have them and I have extensions with the hole that I leave on there all the time. Not something I would go out of my way for, but as something that I got a good deal on they are handy. I have a few "grenade pins" from cam tensioners in the drawer with them for changing sockets.
K
kblee27
Singapore
Thanks all.
So it would be very useful if I need to make a couple of "fixed" size sockets, where I don't intend to swap out frequently. It'd also act like a locking extension where the sockets don't fall off.
I was thinking of putting one on a 10mm deep impact socket, so I could use it on hex shank impact driver.
kctyphoon
Jersey/Staten Island
Just to offer another view.. Pin locks are designed for removable but permant socket retention. You need a tool to remove the socket so it cannot accidently fall off. They are used for production lines or anywhere when having a socket fall off can lead to bad things. Working at heights is another area. Tower workers, lineman ect. They also offer flexibility so you can use different sockets under more than one application when it's cheaper to do so. I have impacts at work that use 5/8 hex chucks, and other that uses 7/16" hex - both with locking quick chucks. I can buy a regular mechanics style (square drive) socket and just swap adapters on the socket to use with different drive style.. So on a single 1" socket, I can't swap out a 7/16" hex to 1/2" square adapter, a 5/8" hex to square adapter, that both use pin locks so the socket can't fall off while I'm using it - and then later take the adapters off and use that same socket on a regular ratchet.. The alternative is buying single, one piece sockets that have each adapter machined onto it, ($200+) which gets very expensive instead of just buying $20 adapters and using one socket.
I have smaller pin lock adapters from apex that I use on a 12v impact driver and 1/4" square drive impact sockets. (instead of a square drive impact wrench) . Using the impact driver with a locking quick chuck, I can use the pin lock adapters so that the sockets CANT fall off 20 feet in the air - but I can quickly swap out to other size sockets that have the same adapters on them using the locking quick chuck on the impact driver, instead of having to stop and get a tool to remove a socket from an impact WRENCH that used a pin lock.
Here's a good pic of the pin lock opposed to a ball detent. Only impact sockets (usually) have a hole in the socket on one side of the square drive so you can use these..
K
kblee27
Singapore
I just ordered a few pieces of 6" pin lock and a set of impact sockets.
https://www.amazon.com/gp/product/B003A4XU3W/?tag=atomicindus08-20
I usually carry around with me a set of "more permanent sockets", 10,12,13mm, so it's faster to swap out with the 1/4" quick change hex shank instead of fumbling with sockets.
Amazon pricing sure has changed fast.
I just ordered at $2.37, now it's $5.07, I think in response to my order.
