Pine floor
dashboard
I have the chance to buy 1250 SF of 2”x 6” tongue and grove pine for $500.00. I would use about ½ of it for a floor in my shop, over concrete.
Good price?
Think I could get rid of the rest of it?
autoist
MEMBER EMERITUS
Gurley, Alabama
Use it all in your house! My entire 2nd floor is done with 2x6 yellow pine T&G (&, it is also the 1st floor's ceiling!).
nate379
Palmer, AK
Wood floor in the shop?! I'd be worried about buring the place down running the welder, torch, grinder... gas, diesel, solvent, etc soaked in there too... WOOOO!
PAToyota
South Central Pennsylvania, USA
I'm finishing up a hickory T&G floor in my woodshop. I was happy I got that for about $1 a square foot. My first inclination for pine in a shop - woodworking or otherwise - is that it is pretty soft and easy to dent or mar.
toolchaser
Greenville, GA
If its southern yellow pine it's actually harder than many "hardwoods". The Hardwood designation actually identifies deciduos (sp?) trees from evergreen. Thats a good price, I paid that 6 yrs ago for 6"x 16' SYP t&g for my house. Its pretty hard stuff.:):)
D
dashboard
It is for a woodworking shop. Thanks guys, I'm off to buy it now; pixs later.
thegarageguy
You may want to check the slab for moisture. You may end up with a bigger mess with mold and or warping. Waterproofing may be needed before you lay down the wood.
Another thing to consider is leaving at least a 1 inch gap or space around your whole perimeter. You may find your floor buckling horribly if you don't.
PAToyota
Yep, "hardwood" basically means deciduous. But pine is still relatively soft in comparison. Take a look at the Janka scale here.
You'll note that yellow pine is down towards the bottom. Oak is about twice as hard. I went with hickory in my woodshop as it is even harder. I do have yellow pine in the house and it is fairly easy to to dent and gouge.
