Pinned or ringed drivers on your impact wrench
Fedwrench
Valley of the sun
I prefer ringed because, I can quickly attach and remove sockets with one hand. The rings are also servicable. I would have to depress the the pin with something and remove the socket on a pinned model which costs time and those seconds add up quickly in the course of a full day.
TNToy
West Tennessee
To the best of my knowledge, in 1/2" and below, a snap-ring on the anvil of your impact is pretty much the default position, as I've never seen anything else. It's also my preference. I just slap a new o-ring and snap-ring on my guns every 6-months or so at work, so they never get to the point where they're dropping sockets too easily.
Even my 3/4" impact has a snap-ring on it's snout.
The only pinned item I own is a 1/2" swivel made by Snap-On. I simply make sure to slip sockets onto it so that the hole isn't aligned with the pin. They stay on just fine, and don't require a punch or screwdriver tip to remove.
vjquan
Ringed. The pinned ones are a pain, and like TNToy mentioned, if you line up the pin with the hole on the socket, a punch is necessary to get it off. I had the Milwaukee 18V cordless 1/2 impact and it had a pin.
rsanter
visalia ca
the pinned are for use with sockets that you will not replace all the time (production work or tire changers, etc)
the ring is for easy socket swaps
bob
L
l_bilyk
Ontario, Canada
I have noticed this too... for some reason my dewalt cordless has a pin, yet I have never come across any retail-oriented impact wrench with a pinned driver
grillmasterp
Which do you prefer?
I prefer a quick release application over locking
There are variations of pin detents -
rounded pin detent performs similarly to hog nose ring.
My milwaukee impact guns came with a locking pin detent which required me to depress the pin to remove the sockets-
I replaced the pin detents with a rounded pin (quick release pin) for convenience
For anyone with a Milwaukee impact with a locking pin-
You can swap it with
49-17-0410
Quick Release detent Kit
