Pioneer mini split extra line set
alex2929
What’s my best option for this extra line length? Pioneer says 10 ft is the minimum but can go as low as 5 but may have to remove some refrigerant. I am guessing if I would shorten I would need about 7ft. I have a void in the wall with wasted space directly behind the indoor unit. I could coil or do whatever with it around the outdoor unit too. Or should I shorten to what I need?
jjrbus
Florida
I installed the line set in a serpentine fashion behind the outdoor unit. Piece of pie!
A
alex2929
Should the condenser not be outside?
It should be but it’s not. Doesn’t really work on the outside the way the building is set up. I have a 20x18 door right next to it and that part of the building is not insulted or anything.
