Pipe clamp handle
vdotmatrix
Northern Virginia
This is so aggravating. The handle comes off or should I say the &^%^&%#$%^#$&^#%^&$%*&^ handle is not attached.
I suppose I could hit it with the MIG, but how do they usually attach these?
paulsomlo
Northern Colorado
Probably just a press fit gone bad. You might try some Loctite sleeve retainer or just drill from the side and use a roll pin. I suppose if it's a close enough fit, you might be able to center punch the end of the screw to expand it, with the handle in place.
Lwel9226
So Oregon
I have some of those that I have taken the handle off and welded a 5/8 nut on in it's place then use a wrench for the handle....
Works great for getting into tight places.... But... BEWARE.... You have more leverage and can bend pipes very easily..... :devilish:
If you try to weld your original handle.... It is cast iron and the bolt is steel so the weld will be poor....
LynnW
neophyte
Pennsylvannia
Just push the driver back on, and center punch the stud on the sides in a couple places.
Or buy the wonderful gray concrete metal epoxy available at home depot.
driftpin
I would drill & pin it or drill & tap the handle with a set screw that fits into a drilled recess in the shaft
I have a shelf support shaft on a wire rack shelving that had the threaded insert loosen, the one that has a female threaded hole to accept the male threaded caster stud. I fixed it by what you suggested, drilling/tapping the shelf support shaft for a 1/4" X 20tpi hex head machine screw.
Drilling/pinning it would be easier, but I think a set screw would avoid removing any metal from the stud the handle mounts-to. Looks like you have plenty of thickness on the wall handle to drill/thread it.
Milton Shaw
LynnW
Use schedule 80 pipe and you will have no problems with bending pipe. At last twice as stiff as schedule 40
