Pipe cutter for irrigation recommendation
nieuport17
I have a Ridgid RC 1625 pvc cutter, which is a very nice pipe cutter. But, in a dirt/soil/irrigation conditions, the tool would jammed up. I have to open it up after every job and clean it.
Anyone have a recommendation on pipe cutter in this area?
Thanks in advance.
Kaizen
New England
Cheapest ratcheting cutters that work. Oil the **** out of them. Clean dirt out before using
Git
S Cal
That looks like a very nice tool. I think the one I have cost about $12...
If you can't clear the dirt away from the area you are working in, try one of these cable saws
Max78
Tucson, AZ
That looks like a really nice precisely built cutter there, great for getting perfect cuts in good conditions.
I purchased a cheap pair from from one of the box stores, its looser fitting and does a good job of not getting gummed up when gutting in the mud. Kind of like the AK47 vs M16, sloppy loose and works good.
There is also this I found.
https://www.lowes.com/pd/KNIPEX-1-3-8-in-PVC-cutter/1001878922
Super Mech
Bronx,NY
As Git mentioned above, a cable saw is what I use whenever I need to repair or modify something on my in ground sprinklers or pond plumbing. Quick and gets in very tight spots.
matt_i
SE Michigan
I have the same pipe cutter but dig a bigger hole.
The way I look at it, if you can't keep the pipe cutter clean, then how to keep the cut end of the pipe clean for prime and glue. Also I don't like to introduce a bunch of soil into the line.
After some fails for contamination I dig a bigger hole and spend more time cleaning around the pipe.
robertmvert
pendleton, or
I highly recommend the Milwaukee m12 pipe cutter. It works very well, makes pipe cutting a breeze. If you primarily run schedule 40, which I'll never understand running schedule 200, works great. I already have Milwaukee, so it was a no brainer for the bare tool cost. If I remember correctly, about $135 or so when I got it.
Sent from my SM-G977U using Tapatalk
