Pipe Dope
whejdak
Here is a stupid question, but I don't know the answer to.
Can I use the pipe dope that I use for sealing water connections on npt air connections.
Is it the same or different . Not talking about plumber puddy.
dogdog
I used it white pipe dope, in conjunction with the blue or white or yellow teflon tapes... which ever one I get my hands on if the thread is questionable. Only place you shouldn't do it is Oxygen Lines....
W
whejdak
Mine just says "Oatey" Great White Pipe Joint Compound.
I'm sure it is the right stuff after reading the label over a couple of time...s
Spareparts
Lansing Ks.
I don't use tape of any kind on air or hydraulic lines, someone will over apply tape and small pieces
always get into valves, especially pilot controlled valves.
ycgoat
S.E. Va
I use pipe dope air line fittings, depending on the thread type it may not even be needed. None of my stuff is rated over 300 psi
msharley
Central Pennsylvania
Yes.
For screw pipe connections it will be fine.
Pipe Dope is a lubricant...allowing the tapered threads to "mate".
T444e
The same dope can be used, but I prefer Loctite 545 as well.
dogdog
The correct way for those tape is don’t wrap it on the first thread
Monza Harry
Windsor ON
I do not like the tape and dope approach at all. The proper dope is the answer. The 545, 567, and 590 are all pretty good but for stubborn leaks I use Loctite 577. I took a quick look at the "Henkel" site and without opening the MSDS's I didn't see the upper temp rating for any of these, and with compressor discharge temperatures of 300°+ possible that should be checked before making your final choice.
At 1 shop I worked at we were to use "RTV silicone" on pipe fittings as re-tapping the hardened parts at that time was problematic at best [deformed slightly due to heat treat] now that is considered pretty hack for sure but it did work], however changing your mind about sealant was equally problematic! RTV is also pushing the temperature limits as well. Edit: 650° should be enough. Harry
ALinCarolina
NC Piedmont
Few years ago I called Rectorseal and asked whether #5 or Teflon would be indicated for compressed air and the CSR said either would be fine.
Doozer75
Buffalo NY
The only reliable method I have found for sealing
3/8" NPT 10,000 psi hydraulic fittings,
is to apply Loctite 567 or 577 to the male fitting
and wrap over the Loctite with thick teflon tape
at least 4 turns. Yes your fingers will get full of
the sealant, but prepared correctly, this will seal
10,000 psi oil, and will not extrude from the threads.
I believe Loctite PST is the same stuff.
-Doozer
W
whejdak
It looks like Loctite is the winner. Tape the loser.
I hadn't thought about the fact that the area I'm using it for is going to get pretty hot.
I'll look closer at the white stuff i was going to use.
housewolf
East Texas
Rectorseal #5 has been my go to for a lot of years. If you have a leaking threaded joint, it isn’t likely because you used the wrong pipe dope. If you have a problematic joint that will not hold, like annealed copper threads, Expando will do the trick.
There is dope available for O2 piping
metalmagpie
Seattle
If you mix red lead powder (litharge) and glycerine in the correct ratio and apply it to threads, the compound will dry hard as stone. This is old school and cannot be unthreaded without heat, but it will never leak.
