Mr.Nutcase
cover your ***. get a quality one !!
I've taken my Snap-on tools to the salvage yard, but they are insight and within arms reach AT ALL TIMES.
Try pulling an engine, then it gets tougher. I believe you might have brought SO tools to the salvage yard to get what? A headlight assembly!
High end tools are not worth taking to the salvage yard, to risky, and not necessary IMHO.
Yeah no way i would ever take any Snap on tools to a salvage yard, Of course our salvage yards may be different, No asphalt or concrete floors... Im talking Knee deep mud holes.
not a cheap import, but imported none the less.
I also turned the torque up about 5 ft. lbs. to make sure the first wrench didn't over torque, resulting in no further tightening. Then in both cases, the fastener did turn until the extra torque was achieved.
I can tell you they aren't made in Pittsburgh or anywhere in this country for that matter. I have a special box for any Pittsburgh tools I might run across.
that may be, but anyone who thinks that a pittsburgh tool in a harbor freight is american made must be pretty naive. if you can't figure that out you maybe should not be trying to fix something.There should be a law against naming tools/companies to fool buyers into thinking they are supporting American manufacturing.
Just for the sake of it, I did a little torque wrench test.
I would tighten a fastener with a PI wrench, then use the HF wrench, and vice versa, in both cases neither wrench tried to tighten the fastener anymore, after the other wrench torqued it.I also turned the torque up about 5 ft. lbs. to make sure the first wrench didn't over torque, resulting in no further tightening. Then in both cases, the fastener did turn until the extra torque was achieved.
I varied the setting from 30 ft. lbs. to 120 ft. lbs., same results every time.
This tells me, the HF wrench is pretty much, dead on
The PI wrench is a much nicer tool, flex head, nicer ratcheting action, easier to set torque and a better lock mechanism to secure setting.
My conclusion, if my HF wrenches are the "norm" (both the 3/8 and 1/2 inch drive) they are accurate. They are not the most pleasant to use, and are crude in comparison to the Precision Instrument torque wrenches.
If you are a bargain hunter, it seems as though the HF wrench will be accurate, just not ideal in comparison with the fine name brands.
Your conclusion is statistically insignificant, it is mearly an observation. The problem isn't with the accuracy of one tool. One of the main problems with China tools is the quality control measures are not consistant across the board or tool to tool. Your tool may have checked perfect but what will it check in six months? What would the next one in line check? If I had to purchase China tools I would not want that purchase to be something I was depending on to be accurate.
The empirical and observational data shown in this thread by members that I think are reliable and trustworthy prove to me that HF torque wrenches will get the job done reliably albeit more roughly and without the fine feel that a US (or other like my Britool) torque wrench give you.
Good enough for me.![]()
My father also had one that was off by 50 or so pounds and striped out the block on his 67 impala that he was rebuilding the factory 327. He had to get helicoils and put them in on the block for both heads. I did have it calibrated after, but he would never use it again because of what happened. I can't say they are all like that, I think a random fluke. But seriously I wonder how often the snap on, precision instruments split beam need to be calibrated and or lose the factory calibration? Also a that time I worked at AlliedSignal and they calibrated if for me for free, and no they didn't use HF wrenches, but I can't say which are better. I do own a snap on split beam and after using a split beam that is the only type I would ever buy because I like the loud click on them.
I bought one a few months ago based on the positive reviews I had read. Unfortunately I didn't realize the thing wouldn't click at all until I had half my engine torn apart and needed a torque wrench to put it back together. It may have just been a bad one. Just make sure if you get one to check it out first and make sure the thing works.
Well I actually went out and bought a harbor freight 1/2 inch torque wrench to tighten down my lugnuts. Now I am not a professional mechanic by any means, but I do most of the car repairs myself. The only thing I used the wrench for is to tighten the lugnuts. Well the 2nd time I used it, the little ball that holds the socket on popped out and rolled down the driveway never to be seen again. So now when I use it I have to be sure to keep the socket from falling off the ratchet. I'll exchange it next time I am in HF but that could be 6 months from now.
The 2-3 times I did use it, I was think it did a great job. I have nothing to double check it with other then my breaker bar. And they were on tight enough my wheels haven't fallen off.
So my conclusion is that their a fail, only because the little ball fell out. I'll still use the tool, and will exchange it for a new one when I get around to it and if I had to do over again I'll but it. But take into consideration that I am a weekend warrior and my livelihood doesn't depend on my tools.
For a guy that has been a member here for all of four months and has over 1700 posts when do ya find the time to really use all those high price tools you have?
The HF/Pittsburgh torque wrench is on sale for $9.99. Run for the gold all you Pittsburgh tool lovers. In all seriousness I might actually pick one up to keep in car for lugnuts and stuff and to "check" my old Husky ones.
because the 36 inch ridgid pipe wrench is overkill.Thank you for your interest in Mickey's high quality USA made hand tools and how much use they get. First let me start by clearing up a common myth, Mickey's tools are not "high price tools", they are expensive high quality USA made hand tools bought inexpensively, sometimes for even less than the inferior tools available at Harbor Freight. As for there use I believe Mickey used his cannon plug pliers just yesterday to open a very stubborn lid on a jar of Skippy peanut butter.
