Hi everyone,
New to the forums. Been planning to Epoxy our garage floor. Read some of the other posts. Now I have a specific question.
From what I've been reading, Epoxy-Coat seems to get pretty good reviews. The local Lowe's has it in stock for the "full-kit" and at a pretty good price, and I can also use the 10% off coupon and even their 10% tax break gift card - so the price is even better!
I'd like to add some of the Sherman-Williams Shark Grip - which I've seen some other posters added to their Epoxy.
Here's my question. Epoxy-Coat comes with Aluminum Oxide for traction - which I've read is very abrasive and you don't want to fall on it! Shark Grip seems to get good reviews - but people typically put in into a Clear Coat over the Epoxy. I can't spend the money for the full Epoxy-Coat kit + Clear Coat, so I'm thinking about buying the Epoxy-Coat kit from Lowe's, and then using the Rustoleum Clear Coat with Shark Grip added.
I have a standard 2-car garage - mainly for everyday home use. No heavy lifting or car work. Built in 2005. Never been coated. I live in Temecula, CA zip 92591.
Can I add the Shark Grip to the Epoxy-Coat layer? Or, is it more advisable to use the Clear Coat? The Clear Coat will be another $99.
Also, what's the feeling on Acid prep vs. Diamond Grind? Diamond Grind seems better but I can't find anywhere locally to rent it - or rental will be over $100.
Thanks!
Thanks!
