misterfixit
Been a while since I've posted here, been reading though. My last build was our home "Barndominium", and then just a few years later we added on. That is now our home. The built in 'garage' of the Barndo has been outgrown and it's time to build a separate dedicated shop building. For some particulars, I will be building in Kaufman County Texas, basically next door to Dallas. I have about 30 acres in the country, outside the city limits. There are no permits and no inspections, I say that because often folks assume that it will have to pass a certain code or to satisfy the inspector but in this case it only has to satisfy me. I don't say that to make you think I want to cut corners or do shoddy work, I want this to be perfect, it's just a reality that no one besides myself will be overseeing or even care what or how it gets built.
I'm planning on a 30x50 shop. I will have a slab poured and then build up myself. Columns will be steel 3x3 heavy square tubing, perlins will be 1.5x4 "C" channel. Trusses will be 1.5x1.5" sq. tubing. Building will be insulated with a 'solar guard" roll insulation, outer skin will be 26ga R-panel. This will be a workshop with both woodworking and metalworking equipment. I don't do cars, no lifts will be added.
I'm getting bids much higher than what I anticipated, like 2 times as much or more. I've done a bit of everything and have poured some concrete, although I lack the tools to finish it. I've looked and it appears guys are marking up both steel (rebar) and concrete substantially. I've had guys suggest just a 4" floating slab is enough, which I don't think it is.
I've priced materials myself and am thinking of setting forms and steel myself and paying someone to pour and finish. I can get pour an finish done for about $1.50/sq ft.
My question is what slab design do I set up? I can set up to pour a 4" slab with perimeter beams as well as cross beams. The beams actually use more concrete than the 4" flat part of the slab. I could actually set up and pour an 8" thick floating slab (3000psi mix) with no beams, reinforced with #5 steel for less than what most contractors have bid for a simple 4" floating slab.
We don't really get ground freezes here, except maybe once a year for a day or so.
So, what would folks think about a 6" or 8" thick floating slab for a simple metal building?
Before anyone says 'Pole Barn', I have considered it. My thoughts are this: anything in the ground, be it round concrete support for pole, or beams on a foundation are going to be subject to the swelling and movement of the soil trying to heave it up when wet and letting it fall when dry. Would a floating slab not alleviate that issue?
Love to hear thoughts and suggestions
