fineford
Morning all,
I've just come across this site and after reading some comments liked what I saw!! Is there a way of viewing some of your garages/shops? I've just built a new shop/garage and need your help/advise re air lines. First of all I'm thinking of running a loop of 3/4 copper from the compressor round the back wall and down the far side wall. Then another loop down the other side wall. Now what I'm not sure of are the drops. I'm going to go with 1/2 copper drops but are they to be vertical down or can I solder them vertical up? My way of thinking is any moisture will be contained in the 3/4 horizontal pipe if I run vertical up "legs". If I add a blow off valve at the end of each end of the loops then any residual moisture can be blown off at days end. Thanks for any help/advice...appreciate it immensley!!!
