Prometheus
- Joined
- May 17, 2006
- Messages
- 104
Hi everyone.
My wife and I recently bought a new house and are expected to take possession the end of this month or early November. The garage needs some care, and I figured what better time to do the floor then before we move all of our junk in!
The concrete in our new house is in pretty decent shape and I'm planning on going with an epoxy-coat kit. I talked to Christine today because I'm a little worried about coverage. The garage is 22x24, so 530 square feet. The concrete looks a little patchy like the penetration might not be consistent. I know this is a textbook case for using a primer prior to laying down the epoxy.
I'm probably going to use the Legacy Industrial Standard Primer and lay the epoxy-coat on top of that. I'm wondering if anyone has done this combo before (I would think so...) and what the results were. Also, how long should the primer cure prior to putting down the epoxy-coat? Is there a maximum time? My plan is to do the prep over 1-2 days, do the primer coat. Wait until the next day, do the base coat of epoxy-coat, then the next day do the clear overtop of it all. So probably a 3-4 day process depending on if prep takes me 1 or 2 days.
The only catch to all of this is that it will be November in Michigan. Christine said as long as the slab is ~45 degrees for ~3 hours the epoxy-coat will be ok. Has anyone tried heating the garage so the slab warms up and then coating the floor with either the Legacy product or epoxy-coat? I would hate to do all the prep work and then ruin an install because the temps weren't quite right. Thanks.
-Adrian
-Adrian
