Plans for Welding fumes extractor
sberry
Brethren, Michigan
Several ways to do it.
bullnerd
Jersey
Check on Welding tips and tricks .com. I think he builds a downdraft table, But it could probably be modded into an arm style.
ripper70
Oregon Coast
I'm looking for a set of plans for a Welding Fumes Extractor, Found a source for filters, would like to save a few bucks and build one myself.
Motoretro
posted this on wrong thread..lol
I built this system to **** out the fumes from welding. Its works VERY well. As im welding you can see the smoke being sucked up and out. Ive got an adapter to hook to the main line that will have a damper for a piece of 25' flex that will attach to a portable hood im going to build on casters. Heres a pic
Heres my build: http://garagejournal.com/forum/showthread.php?t=225559
Robert Hall
Utah
I have a darkroom which is 40x20. I have 2 600 cfm fans that can evacuate the hydrogen sulfide gas from some of my alt processes pretty fast.
I have vents over the sink then pipe it right outside.
I plan on doing the same for the garage.
I got the fans from Granger Supply. I made boxes and installed the fans, then just ran the exhaust to the outside.
I tell my students that even a bathroom fan is better than no fan.
good luck
E.rodz
st.paul MN.
here is one that I put in my shop years ago it is called a plymo vent. there is another brand called neederman. my friend has a couple of the plymo vents that he is ready to sell they are not cheap by any means new they are like 1,500 new i do not know what he wants for them but way cheeper than new and they are almost new.
ilovevocs
Toledo, Ohio
E.rods, Thats a trick setup. You use it much in the winter? Does it **** all the heat our of your shop? I have been kicking around the idea of a filtration system to retain heat in winter but i think yours is just a vent right? Wondering if i'm over thinking it.
theknurl
SoCal
ever think of using a waist mounted filter and a mask?:thumbup:
or plumbing fresh air to a mask?
don't do much stick or MIG, so no big smoke problem
and all the stuff I TIG is clean......oxyacet welding/brazing I use a fan to pull fumes and blow it out the door
:beer:
